Possible water pump issue.
Manchester, UK
Burstner t700
Early 2019
Over the last couple of days water is taking it's time coming through, thought it was an air lock so ran it for a bit and came though ok. Went back after a while to draw more and it was a trickle at first then came though, this is on EHU.When on batt only really struggles to come through.ls pump on its way out?.
I don’t think I can help but the problem might be different with a submersible pump than with a pressurised system. Which type have you got?
Do you mean the water works fine on hook up but not on battery?
Sounds like a non return valve letting water drain back.
Is the pump sounding like it's going pretty quickly but the water takes a while to come through? If so first thing to check is if the pump filter housing is cracked.
Yes it does seem that way.
My experience is pumps have a 'life' of about 18 months.
I always carry a spare
I'm now on my third pump, but still not used the spare tyre.
You pump could be on it's way out, it could also have a loose pushfit connection, which is letting air into the system.
You must have some bad luck or something else is off. My water pump is O/E and the van is a 2007 with 141,000 miles on it. I've carried a spare for years and never needed it.
Cheers, will have a look not much I can do till get back in UK, in North East Spain ATM,
Is that a new pump then or can I just buy the NRV?
That type of pump doesn't have a non return valve as such it's part of the way ot works.
You can buy a repair kit but it's only about a tenner cheaper than a new pump.
If you are in NE Spain you could find places to buy a pump or get checked by someone, just a suggestion...
i had problems with my pump a year or so ago, i bought a new pump ,,turns out it was the little filter that was blocked ..it looked ok just looking at ,it but holding it up in front of the computer screen ,it was blocked i blew it out with the compressor and now working great ,,spare pump in van just encase,,
