Hello,
In my 1996 Hymer B584, the cold water works fine, the hot water doesn't come out.
Also, I noticed yesterday, as I worked on the problem, that some water comes out of what I suppose is a pressure relief or overflow hose that looks like it goes into the water lines.
Water comes out even when running the cold water taps, so it shouldn't be pressure, and there would be not overflow, so I am wondering if a non-return valve is the problem? Or is the pipe work set up correctly? You can see the photo of it.
Under the sink, on the floor, there are water pipe, er, splitters, and there appears to be a sensible air release valve to get rid of air pockets. See attached photo.
I tried that and the hot water moved around in it a bit, but none out of the taps, although the pump is running.
Any suggestions as to the cause of the problem? And solution?
