Louisesjpp
My van has an invertor (seemingly rated at a massive 7kW) which is connected to one socket only. The other sockets scattered through the van are connected to the shore line (ie, site hook up power) and the two don't mix for "safety reasons". I'm guessing this is to do with phase alignment: if the invertor's running and mains voltage is applied, and their phases are one-eighty out, the invertor will see a dead short and go pop.
The trouble is we don't use hook-up, the solar, house battery and inverter so far seems to be all we need, and we've ended up festooned with extension cables in the van running from the single socket.
I hit on the idea of plugging the hook-up cable into the invertor's outlet socket and plugging the other end into the van's external hook-up point, so the invertor feeds to van's mains circuit. This way, we'd have power on all the sockets and there'd be no way we could forget to disconnect it if ever we decided to hook up. My husband was nervous of this solution, and asked for further research.
So, will it work?
So, will it work?
