We bought a new Adria last year and the vehicle battery wasn't holding charge at all. After 2 months of messing around by Fiat who would not invoke the warranty as the vehicle wasn't registered and Adria who had been paid and sent it on its way, our dealer took responsibility and replaced the faulty Fiat head unit.
Check your radio/information unit on the dash It should be wired via the leisure battery not the cab battery, It is a two min job for an auto electrician or a* Job I wish I had never started* if you are not confident. The leisure battery is kept topped up by the solar so no significant drain
I had the same problem with my g690d. After good advice on here, I fitted a battery master, problem solved!
The factory fitted system wasn’t keeping the vehicle battery topped up.
Hope this helps.
