Pilote G740 FC wiper blades
Darlington, UK
Pilote
Since 2015
Hi,
The wiper blade for our motorhome has just split. Where is the best place to get a new blade? It is on a Fiat Ducato chassis.
Thanks,
Ger
Spain! 😄 Ours went in Spain so we just got some from on of the China shops, probably possible to get some in the UK from some of the cheaper general type shops. Just make sure you get the ones for your fitting as I recall they changed from the hook type to the modern clips around 2006..
Any motor factor's should have them even amazon if you know the size
Local EuroCarParts or Halfords if you can fit yourself. Halfords will fit them at a price if you can't. Suggest you buy Bosch blades. Just take the old one in and they will match it.
Eurocarparts. Pop in your reg and measure your existing so you know which one to choose
Mine on the Burstner A class were the standard Fiat Ducato size ( 2 of)
Got some Bosch from Eurocarparts.
If it's not an A class then it's standard Ducato blades. I got these at Halfrods
