Pilote 716P drop down bed
Pilote
I have a 2016 Pilote with a drop down bed. The bed mechanism works fine but the screw fixings constantly come loose and cause the bed to swing from front to back and often the screws fall out altogether. Can anyone suggest fixings that will hold the bed more securely?
Screws into what, wood or metal?
Put bolts through with nyloc nuts?
Photo would help.
The bottom picture is one of the bolts that falls out. We’ve had to cut into the cupboard to access the bolts as they are inside the cupboards that come down with the bed when it is lowered. Any help gratefully received
Can't get to mine to check (I have a Pilote with DD), but the bolts you have should have a lock washer of some type and/or loctite on the threads, try that and it should be fine....
