My first post.....but have been learning a lot on the forum since July. Really helpful when I am starting out on my first DIY van build where I've told the wife it's all within my capability..... so thank you!!
What's the 'Electrical Connections Interface box'? (apologies if I am asking you to suck eggs here...)
Its located at the bottom of the (UK) driver’s side ‘B’ pillar (next to the handbrake). Fiat refer to it as an “Electrical Interface Supply Socket (For Conversions)” option 081 and Citroen simply the “Conversion interface box”. Across all manufacturers it is an optional extra, specified at manufacture.
Its intended use is for vehicle converters who wish to interface with the vehicle electrics and caters for the following;
Extremely useful for all whose converting their own van but only any good, if it was specified at manufacturer. In my case, sadly, it was not.
I need/want to pick up a D+ Signal to run to by Victron B2B Charger. I know there are other ways around this (live feed from ACC or a simple switch even) but being a perfectionist I am keen to go the D+route if at all impossible.
Traditionally, alternators have a D+ output but from want I can gather on a 68 plate Boxer van the output on the alternator is a Can-bus affair running to the NBC (On-board Computer) located behind the passenger side dash. Not overly happy about splicing into that nor routing the cabling through the bulkhead.
I found a Training Manual for the Boxer van on line and it appears that pin 25 on the AV connector on the Front Face of the NBC is an 'Alternator D+ Positive Signal'.
My question is this...Has anyone spliced into this to run to the trigger connector on a Relay (with Diode) to simulate a D+ signal?
- A switched 12V signal which is live when the ignition is on (KEY+)
- A charging signal (from which a D+ “charging” signal can be obtained)
- High current connections to the cab battery
- Rear speaker connections
