Peugeot boxer autosleeper palermo graphics
somerset
coachbuilt
Hi guys anybody know ir I can get original decals for van thanks in advance,20 years old
Thanks guys I have a sign firm that has give me a quote. Is it hard to take old ones off
You will get the old ones off by arming them but you may have difficulty positioning the new ones and gratin them installed without air bubbles, I dont't know as Iv'e never done it but I think it's something you should consider before committing yourself to go ahead.
To apply new ones ..Mix washing up liquid and water in a spray bottle,wet area where graphic is going (wet not dampen) apply graphic from 1 end working air bubbles out as you go(credit card or stiff squeegee(spraying if reqd) apply lots of pressure(you are trying to squeeze all the soap water from between the body and graphic) when fully applied and satisfied ,Very carefully removed face paper...it will probably try and bring graphic with it so go slowly watching and if needed reapply graphic edge.
Once paper is removed carefully work any remaining air out to the edges with finger ( being careful not to stretch the vinyl)any that can't be worked out can be burst with a sharp pin and carefully pressed into place
