- Jul 6, 2009
- 2,088
- 2,651
Our A class having no rear window and being concerned at how close some driver seem to get these days thought I would supplement the reversing camera which only looks back about 8 ft with a permanent one. As the van is 5 years old and still has a damp warranty till it’s 10 I wanted to fit it without penetrating the body. It’s already got to go in for damp found in thhe boot at the last check, considering it had no inner seals fitted to the doors and a lot of moaning to get burstner to supply the seals FOC. It wasn’t about the cost its the principle. Anyway enough of the moan. Bought a wireless one from Amazon as did not want the hassle of getting the camera lead all the way to the front so bought this one.
It states that permanent use could shorten the life so decided to run a power cable up to the front so could turn it on when needed. A thin power wire is much easier to handle than a data one. The number plate is in a body moulding that does not enter the main body so drilling a hole above the number plate wont effect the damp warranty, along the chassis to the drop vent under the oven, up through behind the cupboards and along to the overcab bed clipped it to the wire that goes to the lights so no drama and across to the monitor which is mounted under the overhead bed. Easy to reach to turn on and off so long run small sliver button just in front of the monitor. On a dual carriageway or motorway not so bed but ideal for narrow roads.
