Soots
Oops, and that's what I've put on my motorhome!No they're Continental VancoCampers 14000mls.
No it didn't fail.Is it an mot failure if in the tread area?
I had similar on car tyres and it passed ok. If not an mot failure nothing to worry about ?No it didn't fail.
Used regularly I wouldn't expect it to happen, although overall mileage is a bit low I would have thought enough to prevent problems.Yes it goes out most weeks, I take the dog out walking or go shopping, so far it's done 14000 miles
You need to contact Continental UK giving them photographs of all the issues, tyre info like date of manufacture which is on the side wall and what pressures you run them at for each given axle weight.Has anyone had experience of their tyres perishing?
I've taken my CV20 for it's 1st MOT this morning and found that all 4 tyres are perishing with in the tread, I know Swift caravans had a 3 year warranty on tyres, but do Elddis/Fiat?
Thanks for any helpful advice in advance.
Soots
Please let me begin by giving you an explanation of the condition evident on your tyres.
The condition is a superficial cracking of the tread cap rubber. It does not extend beyond this layer and beneath the tread rubber is the base rubber compound, cap ply, steel belt package, carcass and Inner Liner. (See diagram).
Cracks or crazing of this nature may be caused by a variety of factors other than the tyre itself. These include rising ozone levels, poor tyre inflation pressure maintenance or frequent overloading. We also suspect but cannot confirm that frequent use of chemicals within the car washing process may be an aggravating factor and tyres that are used infrequently or in applications that result in only very short low speed journeys do appear to be more susceptible to this condition. This said, the number of tyres affected, compared to the sales volume, is extremely low and as we have observed similar symptoms on competitor brands of tyres it is not peculiar to Continental.
Tyres with silica based tread compounds that are required to give the highest levels of wet braking and rolling resistance do appear to be more affected than carbon black reinforced compounds. As tyres with silica compounds are progressively more common it may give the impression that the number of tyres with the symptom has slightly increased. As a result of our market observations Continental is continuously introducing improvement measures to reduce the occurrence of this type of condition even though the performance characteristics of the tyre (e.g. wet grip, handling, mileage, rolling resistance) are not affected and we can confirm that tyres exhibiting groove cracks can continue to be used in normal service. The symptom is therefore cosmetic and does not affect vehicle safety.
As I have pointed out this is not a safety concern, however if you do as mentioned feel you wish to remove your tyres you can replace the tyres at your local tyre dealer paying for them as you would normally and then simply ask the dealer to return the tyres using the standard complaint procedure. You will be asked to complete a standard complaint form (SAF) which is used by all the tyre manufacturers so the dealer should have some ( I have enclosed one anyway ). We will then collect the tyres inspect them and once the condition and tread depths have been confirmed a financial payment will be passed back to you via the tyres dealer, normally by cheque. This is the normal warranty complaint process for any make of tyre because due to the many different conditions on a tyre it must be examined by the manufacturer to determine the likely reasons for the complaint condition and only after this, if appropriate, is a commercial payment offered which is based on the remaining tread depth of the tyre. This straight forward and in many cases is the best method of resolving the concern because the tyres can be replaced immediately and the complaint tyres returned by the fitting tyre dealer meaning the drivers inconvenience is minimised.
I hope this goes some way to addressing your concern.
Best Regards
Tomasz Wojciechowski
Technical Specialist Engineer
Direct Line: +44 (0)1788 566 240
Fax: +44 (0)1788 517731
E-Mail: administrator.technical@conti.de
Web: http:// www.continental-tyres.co.uk
Continental Tyre Group Ltd
DC2 Castle Mound Way
Rugby
United Kingdom
CV23 0WB
I don´t know the UK standard but here in Germany 7 years is when they strongly suggest a change at Tüv time (MOT) and 10 years is when they fail them regardless of tread depth, condition etc.I was speaking to an elderly friend just the other day. His van is due an MOT and 7 years old. It has the original tyres, having only done just over 2000 miles. He was worried the van would fail the MOT based on age. He keeps the tyres covered at home and on rallies/sites. So minimal cracking showing
