no pic. its a 6mm coach bolt with no thread originally about 80mm long and bent into a 180 degree u shapeI can only find mention of the tie down strap on their website, do you have a picture ?
i havnt got a clueDon't they hook over the top of the pull down legs where it meets the awning rail.
I'm only guessing, but at the hinge with the awning rail is probably a gap. If you pass the U bolt through the gap it should sit over the top of the leg. You can then clip the blue clip on the head side for the tie down strap. Only a thought, I have similar, but instead on a U bolt I have a piece of bent metal forming the hook.i havnt got a clue
thanks i have the bent metal storm tie down system myself, i am thinking that this u gizzmo is part of their tie down system. so i think i will recycle it. and thanks againI'm only guessing, but at the hinge with the awning rail is probably a gap. If you pass the U bolt through the gap it should sit over the top of the leg. You can then clip the blue clip on the head side for the tie down strap. Only a thought, I have similar, but instead on a U bolt I have a piece of bent metal forming the hook.
The head is trapped under the Peggy Peg foot that is held down by 4 bolts, you ain't going to blow that out.80mm long.
I could blow that out of the ground.
My storm strap pegs were 450mm re-bar.
