Ditto, apologies for causing confusion!I think I must have the 38L not 35L.
That’s what I thought but SVTech said no, still 3850kg max. We have the uprated (2000kg) Goldsmitt springs on the front already but for some reason SVTech would only plate the front at 1950kg.We could go to 4005kg by fitting uprated springs to the front
Our rear axle is now rated at 2240kg because of the air assist and the 225/70 15 112 index tyres. We never get anywhere near the 1850kg standard front weight limit (usually about
If those are your axle weights then JR was correct. It can always be uprated to the sum total of the axle weights. There is no requirement for a 'safety margin'Just adding our axle weights would give us 4190kg
Not according to Al-K0. Some of their chassis variants have a maximum weight limit of less than the sum of the two axle weights e.g. AMC 37L chassis has a maximum weight of 3700kg but the individual axle weights are 1850kg and 2000kg. Strange but that is what is shown in their technical details, you have to upgrade to the AMC 38L before the axle weights and maximum weight match.If those are your axle weights then JR was correct. It can always be uprated to the sum total of the axle weights. There is no requirement for a 'safety margin'
According to Carthago their Compactlines are build on the 35L chassis as standard, however ours has the 38L and 225/75 R16 tyres, no idea why though; it could be that UK dealers automatically order on the more 'accommodating' chassis so that owners can uprate to 3850kg as we have (and also the ability to increase the rear axle capacity from 200kg to 2240kg by adding semi-air).Not according to Al-K0. Some of their chassis variants have a maximum weight limit of less than the sum of the two axle weights e.g. AMC 37L chassis has a maximum weight of 3700kg but the individual axle weights are 1850kg and 2000kg. Strange but that is what is shown in their technical details, you have to upgrade to the AMC 38L before the axle weights and maximum weight match.
I up rated my van with JR, JR sent me a weight sticker, someone on here said that he stuck it on the passenger door post and not inside the engine next to the old one. Do you know if that’s correct or does it have to be in the engine compartment.
I'll be doing the same, when I am in receipt.I stuck mine under the old one inside the habitation door
AFAIK there is no rule as where it should be stuck. Hymer put theirs on the right hand skirt in front of the rear wheel.I up rated my van with JR, JR sent me a weight sticker, someone on here said that he stuck it on the passenger door post and not inside the engine next to the old one. Do you know if that’s correct or does it have to be in the engine compartment.
Go for the highest you can, thereby reducing the possibility of inadvertently overloading.John said he could plate it at 4100Kg rear axle 2250Kg.
