Former Mechanic & Autoelectrician here. Unless all air is bled out of the High pressure Injector pipes the diesel will not spray into the cylinder. It should have a rotary injection pump with steel pipes connected to it going to the individual injectors which delivers fuel at about 5000 PSI if it does not have this type pump it then has a common rail system which has a very high preassure pump which operates at 15000bars which would drive fuel through your skin. A rotary injection pump requires fuel to be in the pump to lubricate it. Using Easy start if too much is used it can cause the engine to knock or even run backwards or if it does start if the injection pump does not have diesel in it's pump the pump can lock up and cease.
