Good evening funsters. So getting the MoHo ready for a fabulous year of cruising and immediately hit a problem that wasn't there when we put it to bed, namely the push button catches for the overhead lockers have decided that they don't want to work properly anymore. They have become very stiff to press the button in and reluctant to spring back out to engage with the 'keep' - all eight of them showing solidarity with each other which is puzzling in itself.
They are the Swift Sterling type with a smart handle and pushbutton on the outside and a spring loaded plastic catch mechanism on the inside. Simples, I think, a little spray with plastic friendly lube should do the trick - only it doesn't. I have messed around with one (dismounted from the door) and can see no obvious reason why the catch mechanism won't slide freely. It's almost as if the plastic has expanded like badly seasoned wood or something.
So, the questions are:
Thank you.
- has anyone else had this problem and if so, short of buying new catch mechanisms, how did you fix it; and
- does anyone have any maintenance tips for these catches to avoid this problem in the future?
Thank you.
