Hi Everyone
Can you help me to reset my outside temperature sensor, after replacing my wing mirror, Thanks....x
As said above..
it's a simple termperature probe, no calibration or resetting required..
It either works or it doesn't.. but it is important that it works .. apparently the DPF regen needs the ambient temperature feed to work properly ...
thousands-spent-but-still-a-dpf-fault-you-wont-believe-the-cause-peugeot-boxer.286080
Thanks Everyone for your help...I will check if it's got a probe, and go from there...AndyHi Everyone
On my 2006 Hymer A Class it's below the Trauma boiler. It's very nondescript but you can confirm it by putting an ice cube to it and seeing the temperature fall on the control panelCan anyone tell me where the outside temperature gauge is on a Hymer B588DL is located please
I believe this is only relevent to engines with Adblue. Older DPF systems may even not have a temperature sensor.As said above..
I couldn't say for sure .. OPs van is 2016 ... Van in video was 2018I believe this is only relevent to engines with Adblue. Older DPF systems may even not have a temperature sensor.
I'd start looking at the wing mirrorsCan anyone tell me where the outside temperature gauge is on a Hymer B588DL is located please
Nope, but I think it maybe behind the front bumper.We have a B678DL and as long as you have a temp reading I wouldn’t worry I haven’t got a clue where the sensor is but if I ever come across it I will post on here
Lenny HB will probably know
