Outer window seal replacement Rapido 7086f
Rapido 7086f
As anyone replaced an outer window seal on a 2005 Rapido 7086f If so can you tell me how to get the inside screw covers out so that I can remove window frame and replace window seal Also what type of seal did you used Thanks
Hi yes i did our rear bathroom window on our Rapido 999m if yours is the same as mine there are i think 8 screws to hold the inner frame to the window see attached picture just prize the little caps out and the screws are hidden behind them. Undo the screws then remove frame and you should then have access to the window frame screws i after cleaning all the old sealent off used sikaflex 522 from screwfix word of caution on mine don’t tighten the screws on the moulding frame as they screw directly into the wall hope this helps
Tony
