One Or Two? (2 Viewers)
Nov 18, 2016
803
1,227
Worcestershire
Burstner Elegance
I have a nice shiny new HUGE 6’ wide solar panel and a load of new mounts for it. BUT, do I use 1 or 2 big wide mounts on the long sides? One of these long sides will be facing the wind at the front of my van. There will be 4 corner mounts and two short mounts on the short sides too.
May 11, 2023
242
310
Globecar Summit 540
I think I'd do 2 on the front edge and 1 on the back, so air won't get 'trapped' underneath and try to lift it?
Gellyneck
10,217
20,924
Scotland
More than toes wet now!
Might be worth a read?
Sep 29, 2007
896
1,531
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
Firstly I wouldn't use those acrylic brackets. The surface area on the roof is too small for my liking. Just personal preference. They also take up a lot of space increasing the effective length and width.
I would use aero brackets:
They are 67cm long, so if you use a single bracket at the panel ends you'd have a 213mm overhang. Such an overhang would be fine if the panel is not right at the front because you have a reasonably substantial service area for the sika. You'd screw the brackets to the panels, creating a very solid structure. If the panel could experience very heavy drag (e.g. right at the front) I'd get a 2nd set of brackets and cut to size so I have a bracket over entire front of the panel (joined in the middle - you'd not notice it). If I was mounting the panel sideways and near the front I'd want a lot of bracket!
or I would use 25mm x 50mm aluminium rectangular tubing (1.5mm walls). These you could cut to exact size and have a very strong sika bond to the roof. You attach the bars to the panels with self driller/tapping screws. Works a treat. Very strong structure with substantial sika surface area.
or I would use 50mm x 50mm aluminium angle and screw them to the panel sides with self driller/tapping screws. Again you cut to length. Similar to the tubing, substantial surface area.
Do a dry-fit to mark where the sika will sit on the roof. Clean and scuff the area carefully, water -> isopropyl alcohol -> sandpaper -> sika activator
Your sika should be ideally about 3mm thick. Cut about 20mm off the nozzle so it comes out easily. You'd probably want to use a tube at each end (front and back).
A
Nov 18, 2016
803
1,227
Worcestershire
Burstner Elegance
This is the issue. It’s going to be right at the front and sideways. The whole 6ft length will be side on to the wind. I think I’m going to bin ( sell ) the plastic brackets and get two 6ft lengths of 50mm x 50mm angle aluminium and cover both the long sides fully. That’ll stop any wind getting under the front and trying to lift it up.
Thanks for the tips! (y)
Now, which sikaflex……….:LOL:
I’ve used this in the past on the panel I put up about 3 years ago and it was a hell of a fight to get them off again.
Sep 29, 2007
896
1,531
Wantage, UK
We generally use 522, incredibly strong.
Costs more than EBT but worth it.
Sep 29, 2007
896
1,531
Wantage, UK
Aah ok thanks. (y)
Would 75mm x 50mm angle aluminium be better than 50mm x 50mm? Or is that total overkill?
We generally use 50mm x 25mm box section. Most brackets lift the panel 25mm off the roof.
Sep 29, 2007
896
1,531
Wantage, UK
That will create more lift.
I always use 291i more expensive but a lot stronger than 522 even better is 292i
Sika do recommend those as opposed to 522.
That said, I’ve never heard of a panel correctly fitted with 522 (and proper roof prep with enough curing time) coming off.
