OIL AND FILTER CHANGE (1 Viewer)
Oct 5, 2019
578
453
Southport, UK
pilote,g740
since 2019
HI could use a bit of advice on servicing i done the oil and filter a year ago and i have only covered about 2 thousand miles since would you do it again now, or leave it for a few more miles ,,thanks oh its a fiat based ducato 150bhp 2018
Sep 29, 2019
3,243
7,462
Hymer Exsis
20 years
Yes, low mileage means it’s even more imperative the oil is changed. Condensation can build up in engines not used much and dilute the oil.
Quick and easy job and less than £50. 👍
rob1234
Oct 5, 2019
578
453
Southport, UK
pilote,g740
since 2019
hi what oil do you use and where do i get it for £50 with filter ,,
10,427
21,813
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Usually online for best price, euro car parts or gsf car parts delivered or local pick up.
I think the 50 pounds was an indication it's not an expensive job to diy, rather than a calculated quotation.
rob1234
Oct 5, 2019
578
453
Southport, UK
pilote,g740
since 2019
oh ok thought he had somewhere special ,,looking more like £70 now ,,that's covid for you ,,eh
rob1234
Oct 5, 2019
578
453
Southport, UK
pilote,g740
since 2019
hi again do you think even if its long journeys ie,,2 hour trips ,,i did ,,i dont do start,, stop journeys it still needs changing ,,?
rob1234
Oct 5, 2019
578
453
Southport, UK
pilote,g740
since 2019
any one used this just found it on line
Status Car Care 5W30 C3 DEXOS 2 20 Litre Oil 20L Fully Synthetic 5W/30 C3 engine oil is produced from high quality synthetic base oils and top-tier performance additives.​
Stealaway
8,496
11,546
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I'm happy to use 5/30.
0w is only Fiat's attempt a low emissions at start up and another attempt at selling a very expensive oil.
I change mine every two years and 16,000 miles.
Sep 29, 2019
3,243
7,462
Hymer Exsis
20 years
Sorry, I do it myself. Couldn’t tell you which oil, I just get whatever my local motor factor has in.
Think it was £47 last month all in.
TheBig1
Nov 27, 2011
17,851
44,358
The thing with synthetics, is they get acidic if left in on a low mileage engine for extended periods. The Fiat commercial 2 year interval is based more on a typical mileage or when that mileage is reached if under 2 years. I still think it's folly to not change oils yearly to protect a very substantial investment. For most of us the purchase of our motorhome is only second in cost to our homes. You think nothing of servicing the boiler in your house every year
Dec 2, 2019
4,630
10,322
South Lincolnshire
Rapido 7065+
Broken most bits now
I wouldn't bother tbh. Save a few quid and a bit of the planet by extending your oil life, your engine won't notice. Very, very worst case scenario is that you'll need a bottom end rebuild every 20 years or so, not a worry compared to all the other Moho things you'll need to worry about
Oct 29, 2008
5,201
6,339
West Yorkshire
PVC
since 2008
Condensation cannot dilute oil. Oil and water don't mix. Short trips can cause condensation in the engine which would show asmayonaise in the filler cap. It would boil off on a longer trip.
At 12 months and 2000 miles the oil will be as new and not worth changing. Your would do it more good taking it for a decent drive.
Sep 29, 2019
3,243
7,462
Hymer Exsis
20 years
Okay, it’s not my area of expertise but the Haynes manual says it becomes diluted.
Either way, if in doubt, it gets changed every 6 months and 2000 miles a year isn’t a well used hot engine in most circumstances.
John
Oct 29, 2008
5,201
6,339
West Yorkshire
PVC
since 2008
John
Diluted by diesel maybe in time but not 1 year or 2000 miles. You would notice dilution as the oil level would rise or the oil change warning would come on. Plus its only caused by forced DPF regenerations which would not happen for many thousands of miles.
Fiat advise 2 year 36000 miles oil change. I do mine around 12 to 18 months or 6000 miles which I'm sure is still more than necessary.
May 29, 2013
2,696
21,126
Tyneside
Chausson best of Flash 10
Several years now
I emailed Castrol tech services as I had read on their website that the oil was good for 20000 / 2 years. I explained it was for a MH which did 5000 miles per year. Would they advise 2 year oil change or more frequent. They said 2 year was fine.
Now you might say they missed a chance to sell more oil, or they were being genuine in their tech advice, your choice.
rob1234
Oct 5, 2019
578
453
Southport, UK
pilote,g740
since 2019
That sound like good advice think I leave it till next year...got enough to spend on cam belt this year...
Apr 3, 2018
3,943
11,171
PVC
1995-2004 & 2017》
This been on here a few times and the answers you will get is definitely change it..... definitely leave it..
For what it's worth I change my engine oil every year regardless of milage or use..
Aug 18, 2014
24,592
143,061
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yes but is c3 comparable? most these days need acea 4 or 5
That is only for acea 2 or 3 yours probably requires at least acea 4 more likely 5.
rob1234
Oct 5, 2019
578
453
Southport, UK
pilote,g740
since 2019
apparently yes this is the oil recommended by opie oils ,,
Quick View: Millers Oils XF Premium C2/C3 5w-30 Fully Synthetic Engine Oil​
Product Image
Performance Profile:
  • API SN
  • ACEA C2/C3
  • BMW Longlife-04 (Approval Pending)
  • MB 229.52 (Approval Pending), MB 229.51
  • Opel/Vauxhall OV0401547 (Approval Pending)
  • Renault RN0700 / RN0710
Suitable For:
  • API CF
  • Chrysler MS-11106
  • Fiat 9.55535-S3, Fiat 9.55535-S1
  • GM dexos 2, GM-LL-B-025, GM-LL-A-025
  • MB 229.31, MB 226.5
  • PSA B71-2290 <2014
  • VW 502 00 / 505 01, VW 502 00 / 505 00
  • VW 500 00 / 501 01
  • Dacia*
  • Asian manufacturers**
Stealaway
8,496
11,546
Burstner Lyseo 690G
They stock two fully synthetic oils. One is basically for Fiat/BMW and another one for Ford.
My son has two BMW's and only looks for the C3 spec and I've been happy because it suits Fiat as well.
I'm going to check out the specs now - thanks for that :drinks:
The price has gone up £25 per can for both
Stealaway
8,496
11,546
Burstner Lyseo 690G
Its a mine field but I cant find any recommended oil at acea 4 or 5
Selenia WR Forward 0W-30 Euro 6 engine oil for the new Fiat Ducato motorhome engines
Selenia WR (Wide Range) 0W-30 is the new fully synthetic engine oil specially made by Fiat for diesel engines with Euro 6 standards.
The viscosity grade of 0W-30 has a direct influence on the fuel consumption and reduces it, thereby reducing the production of CO2.
Original Fiat engine oil offers the following advantages
  • minimizes fuel consumption
  • High thermal stability
  • Increased engine protection through the use of the original oil
Technical specifications
  • SAE 0W-30
  • ACEA C2
  • Official Fiat approval: Fiat 9.55535-DS1
Selenia WR Pure Energy 5W-30 engine oil Euro 5 emission standard for Fiat Ducato engines
Selenia WR (Wide Range) Pure Energy 5W-30 is a fully synthetic motor oil that meets the requirements of Euro 5 diesel engines. The ACEA-C2 specification certifies the low ash content. This property ensures that the anti-particulate filter is protected against the combustion residue. This prevents the soot particle filter from clogging.
  • It strengthens the protection of the engine
  • It increases the fuel economy of the engine
  • low ash content, which protects the efficiency of the diesel engine
Technical specifications:
  • SAE 5W-30
  • ACEA C2
  • Official Fiat approval: Fiat 9.55535-S1
rob1234
Oct 5, 2019
578
453
Southport, UK
pilote,g740
since 2019
  • SAE 0W-30
  • ACEA C2
  • SAE 5W-30
  • ACEA C2
no neither could i that's why i put the c3 in last year ,,and it will be staying in till i come back from France in July ,,that will be that will be 19 months,,and about 3000 miles ,,ish
Jan 27, 2018
2,832
2,284
Northampton
Rapido & Bongone
In my euro6 Ducato i use
Fuchs TITAN GT1 Pro 2312 0w-30 Premium Performance Fuel Economy Engine Oil This complies with the requirements of the Fiat spec.
I also change every year especialy if low mileage. If you exceeded 10000 pa then Fiat advice is every 2 years. The effect of condensation in the oil is to oxidize the additives and create an acid environment, even more so with high Sulphur fuels. A regular blast up the motorway helps drive away the water preventing acid generation. Another contaminant that is very detrimental to oil is ethelyne glycol, anti freeze, however Modern antifreezes do not contain ethylene glycol any more, but OAT based (not porridge oats). Short start stop runs or long idling are the most detrimental to oils and engines with diesel dilution and varnishing.
-Broken Link Removed-​
Aug 6, 2021
94
147
panel van conversion
Agree with what TOAO says above - from my point of view it's whether to go with the vans oil degradation countdown or a fixed time interval (assuming using an OE filter and approved oil or same quality equivalents for both regimes). I do about 5-6k per year and as I prefer to do my own servicing (on open driveway) it is convenient for me to do it annually in summer when the weather is good and it's a pleasure to be outside. My first countdown after 18 months from new told me needed an oil change late Feb. After that didn't really want to go with the countdown and find it needs doing in January/Feb in maybe bad weather. Also doing it earlier than the countdown can only be beneficial - thats my view.
Sep 28, 2015
2,178
2,870
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
For the first five years our 2014 Ducato based was serviced by a Fiat Professional dealer and they used Fuchs Titan.
