Ohm's (1 Viewer)
Oct 31, 2017
604
1,337
Kent
Carthago T149
Since 2016
My Tomtom satnav has lost its sound, I have checked settings and they seem ok so have come to the conclusion it is the speaker that is faulty.
It has fitted a small 30mm ish speaker 2w 4ohm but I cannot find find one, there are lots of 2w 8ohm speakers around will that be ok to use ?
Sep 26, 2013
4,240
5,268
Market Rasen
Self Build
Since 2003
Iā€™ve had and still got 4 TomToms and they have never done that, It might be that Jane is having a rest.
9,763
25,955
Derbyshire
Elddis Accordo 105
since 2014
Yes no problem šŸ‘
1,378
3,367
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
I had a TomTom that lost sound, using a chat line with TomTom thay suggested various fixes, including uninstall some software etc, after several goes, including postcodes could only be 5 digits, ...they were useless...TomTom asked me if the volume was turned up ...grrrrr....they offered to fix it for Ā£90 plus vat, as a valued customer......
Any way I took it apart and wired up an old earphone and got sound, so the speaker was dead....
Went to local model shop and bought a small speaker used in model railways....Ā£6.....still working after eight years. (y)(y)
Lenny HB
55,856
162,950
On the coast in West Sussex
Carthago Compactline
An 8 ohm speaker will be OK but it will reduce the sound level by 50%.
But if you didn't know that I'm wondering how you determined the speaker has gone as you would need to look at the output with an oscilloscope or connect another speaker.
Roger S
Oct 31, 2017
604
1,337
Kent
Carthago T149
Since 2016
There is no sound at all from the machine, ie from the key pad bleeps, warning sounds, or voice.
Roger S
Oct 31, 2017
604
1,337
Kent
Carthago T149
Since 2016
I have carried out a couple of updates since this happened aswell thinking it may be a software issue.
