that would be isolated rather that insulated and yesI am quite electric blind, and I’m just about to purchase a Victron 30ah dc to dc charger.
My motorhome is a 1995/6 Hymer B654.
Would I be right in saying that the non-insulated version would be fine for this vehicle?
Thank you, again. Just so I’m sure, you are saying the non-isolated version will be ok?that would be isolated rather that insulated and yes
Either will work.
And, for educational purposes, what are the differences and when would you choose one over the other?
Ian
Some vans have a separate 12v leisure system which is not earthed through the vehicle chassis for various reasons, in this case you need the isolated version, if your leisure battery is earthed through your chassis then the none-isolated will work ok.And, for educational purposes, what are the differences and when would you choose one over the other?
Ian
Would using 12v on a 24v truck conversion mean you would need isolated Steve? Not that I am likely to do it, just out of interest really. I though isolated was where there is no common ground or where a common ground in not wanted such as boats as you saidDo you have any examples of what vans, and what reasons?
There was a post last year regards this and op had an isolated system I’ve never come across this myself and have tried to find the post without success, I think it was an A class.Do you have any examples of what vans, and what reasons?
sorry Ian, I'm not really understanding the question but my 24v and 12v systems are both earthed to the chassis.
Can I ask how you did that?Just fitted a none-isolated to my van with no problems, did check continuity to earth from the negative on the leisure battery to make sure I didn’t require the isolated typ.
The leisure battery is under the drivers seat in our van, fitted the Victron to the rear frame of the passenger seat, victron earth to van earth, positive in to vehicle battery and positive out to leisure battery, i used 16mm cable with 2 inline resettable 60amp fuses.Can I ask how you did that?
I have the shunt in and working already. I think this is the wiring that you are suggesting?The SmartShunt is a method of measuring the amps going into and out of a battery. Normally the B terminal connects to the negative terminal of the chosen battery. In your case, you have a pair of leisure batteries that you want to monitor. You can connect one negative to the B terminal, and have a link between the two leisure battery negatives, as in your diagram. Or you can connect two equal links from the B terminal to each of the two leisure batteries. Either way is fine.
However, everything else to the leisure battery negative must go to the SmartShunt A terminal. That includes any B2B connection, and any chassis/earth connection. If anything goes direct to the battery, it bypasses the shunt and cannot be accounted for. So the wire from the DC/DC charger needs to be moved.
The starter battery voltage can be measured using a separate wire from a special terminal. It doesn't go to either A or B. Note that it only measures voltage, not amps and State Of Charge like the main terminals.
I'm replying to this (oldish) thread as it has the same title as the question I was about to ask...In nearly all motorhomes the vehicle electrics and the habitation electrics have a common negative, usually connected to the chassis. In most vehicles the alternator negative is connected directly to the chassis, If you want to charge the leisure battery with a split charge relay, its negative has to be connected to the chassis too. I would say all motorhomes have this, but I recall that one motorhome discussed on here had an isolated habitation system. I think it was built by an ex-boater.
Obviously I don't really know what I'm doing!!!Doesn't solve the problem that the non isolated one is not suitable for Motorhomes unless you really know what you are doing.
In theory, the non-isolated version is better than the isolated version for use in a vehicle because usually the two battery negatives are connected to the chassis, which is a requirement for example for charging both batteries via the split charge relay. However in practice there are problems, but they are similar to the problems an isolated version would also have.I'm replying to this (oldish) thread as it has the same title as the question I was about to ask...
I'd thought that a non-isolated B2B was what I wanted for My Pilote, until I came across this remark by Lenny HB in reply #8 to this thread: 2 x victron 12-12 -30 non isolated chargers from engine battery what size positive cable is needed where he said
Thanks - I'd understood the distinction between MHs and PVCs as far as the chassis was concerned but I thought I must be missing something else!If properly installed, the isolated or non-isolated version is fine, and the non-isolated version is less expensive
