...following on from my Dodgy diesel thread, turns out it wasn't poor fuel.
In summary, I have the following engine symptoms with my 2007 Ducato 2.3:
-Sometimes when starting, it idles but there's no power. This goes away after a couple of minutes.
-MPG seems to be about 15% worse at the moment.
-It sounds a bit grumbly under load and I think it's a little underpowered compared to earlier in the year.
-I'm getting an occasional whining noise from under the bonnet. I thought it was powered steering... but now...
-No engine warning lights or OBD codes (yet)
I've spent all morning trying to work out whether to attempt to replace by throttle body as the consensus is that it's probably the issue. However, it looks like the previous owner has already replaced it with the newer 'no water ingress' version:
I've got no idea why it's covered in oily crap on the outside, but I can't see any obvious leaks. I guess that lone yellow connector block was probably from the old throttle body and the new one connects back to the loom with a different cable?
Anyway, randomly I came across a thread on the O&A forum that suggested a test... so I gave it a go:
What you can't really hear from the video is not only does the solenoid stop buzzing, but the engine sounds much less laboured when the pipe is disconnected.
So it looks like my ERG solenoid valve is playing up. Do I replace it, or is something else causing the problem??? I've not found the part online yet. I'm hoping it's cheap!
