No water
Burstner 680g Ixeo
Ownner for two years
water
There is now a slow run of water, just slightly more than a trickle. I Have checked the system again & valve positions all ok. Pump tapped, shower hose sucked & primed. Pump still making a buzing sound when tap is open. Could it be the pump? Any more suggestions gratefully accepted before I go to a dealer!
Those pumps are not too expensive. I have replaced a couple in the past. They do burn out quite easily.
Internal.pump? Impellers can break up. External pump - remove outlet side and flick on to see if pressure is good from pump itself.
Can you get to the output pipe at the pump and remove it. Then run the pump for a second o see what output you have?
