no its live as soon as the 12v is switched onDo you have e a separate pump switch on the control panel marked RES?
I replaced any strip connectors with Wagos where possible, they actively hold the cores with a spring action.all done now a terminal block down the side of the watertank had a loose screw in the block so after making a mountain out of a loose wire all done thanks for the help
