Is that off grid and via an inverter or with EHU connected?However microwave works.
Control no power so cannot check voltage. Bailey Autograph 79-4F.Assume you are on hook up hence microwave works.
Would be very helpful if you said what MH you have?
First off Check Hab battery voltage, needs to be 12v+
sorry assumed you had a multimeter circa £10-20 unable to check any electric issue without one----- unless using an appropriate voltage test lamp.Control no power so cannot check voltage. Bailey Autograph 79-4F.
Have the control panel, lights and fridge been working O.K. or is this the first time out in a new-to-you m/home?
You need some sort of test gear, if you don't have a meter (DVM) you can either buy (Cheap cheerful jobby) or at the very least get a 12 car lamp and holder, connect a couple of lengths of wire (circa 12-18") to the lamp holder. terminals and uUsing a couple of pieces of terminal strip (choc Block) and a couple of small nails. Use the terminal strip to join one wire of the two from the lamp holder to a nail and ditto the second wire.Control no power so cannot check voltage. Bailey Autograph 79-4F.
