Evening all. First time out this season and can’t get the happy green light on my Maxview tv signal amp to light. Switch is on but no green light. I’m in Henley on Thames, so not exactly remote. Is there a separate fuse on Adria Matrix 690?
As above...undo the fuse holder and pull out the fuse. Without your tester it may be difficult to prove ok or not but you could pull out the spring inside the fuse holder and just give it a small pull to extend it a little. Just in case the fuse is not making contact properly then put it back and retest with 12v on. If it comes on...wuppeeee! Job done! If not...power failed at fuse possibly?
Kev
