No onboard water - help please
faraway
Kent
Chausson Flash 10
Getting better
Hello. In my Chausson Flash 10 I have a problem with no water! After using water over the last two days and turning off the tap, the pump (I think) continued making a sound for a very short while, but it is not usual. This morning, using a tap (mixer tap) for the second time, no water came out at all. This applies to all taps and the toilet. No sound from the pump, the tank is full and the main board is on. Anything I can do (in very simple terms please!) to check or does this sound as if the pump has died and needs to be replaced?
Check the Fuse, If you have a multimeter, check your pump switch and the power terminals on the pump for voltage. if you have voltage in these places them probably a dead pump.
I am sure someone will be along in a while for more suggestions
Check the wires to the pump too and I know its obvious but the light on the panel to show the pump is on.
As above check the fuses first and make sure you have a supply voltage to the pump. A sensor normally switches the pump on and off so you are going to have to check the sensor if you have a voltage at the pump.
Thanks all, sounds as if I'm going to have to go and see someone!
I was going to say that the pumps is really easy to replace and then thought but only of you can access the tank!
When we replaced ours it was a question of taking the cushions off the seat above the water tank, unscrewing the access lid of the tank, pulling out the old pump, taking off the wires from the old pump one at a time and attaching to the new pump in the equivalent place (after making sure the electric is off of course) and the same with the water pipes. Then replace the seat cushions. Took longer to do the cushions than replace the pump.
But then your pump might not be the same as ours and the access might be a pain.
There is a switch with a picture of a tap and that needs to be on.
Many thanks, I don't trust myself with those sort of repairs!
the dealer replaced one for us and showed how it was done. When the second one went we just did it ourselves. the thought is worse than the act :)
My pump Shurflo on Rapido was a right bogger to replace. The hex bolts holding it were a weird size and the bolts had siezed in the captive nuts embedded in the plastic of the water tank. Its now just held with self tappers so easier to do next time
:sneaky:
We don't know yet whether it is a sureflow type out of the tank or a submersible in the tank or in fact if it is controlled by microseconds or pressure switch----do we????
Unfortunately not. I'm very keen to learn though, so if someone can tell me what I'm looking for and where, I would appreciate it.
Have a look under the bathroom or kitchen sink and if there are any wires coming away from the taps then it is microswitched.
Martin
Won't help you now but I always carry a 10L container of fresh drinking water for tea making and emergencies such as pump failure or hab battery problems
My pump did exactly the same thing a couple of weeks ago, it was a breeze to replace.
Mine is a Shurflo and is situated in the storage area under one of the side seats. One of the very knowledgable and kind souls one here gave me a simple way to test the pump and give me the use of it (as we were away on a break). Take a 10amp blade fuse and attach the 2 power connectors from the pump (there are only 2) to either end of the fuse and use the pump on/off switch on the control panel to activate. This tells you if the pump is knackered or just the micro switch. The micro switch is replaceable but for the cost involved, for me, it was easier just to replace the pump.
Martin
Thanks. Have had a look and don't see any wires.
Thank you, will have a look under the side seat.
