- May 14, 2018
- 378
- 523
- Autograph 794-T
- Caravan owner moved on to Motorhome
So I started the relatively simple task of adding an additional leisure battery (ready for installing an inverter). Switched everything off. Powered off the Consumer Unit. Disconnected the Solar Panel. Installed the new battery in parallel. Powered everything up. Panel showed 12.7V everything worked. Powered up the consumer unit and expected to see 14.7 on the panel (ie. charging).. still showing 12.7V.
Consumer unit trips when I press the button, so there is 240v going to it. The Solar is happily showing the state of the leisure and cab battery and is 'charging it' (even in this crap weather) with 0.4A. 12v is powering lights, heating pump etc etc. But no charging seems to be coming from the 240v consumer unit. The charger in the consumer unit is 'warm' not stone cold (which I would expect if was knackered).
I'm assuming the charger is knackered as I am seeing a current draw on the battery when on EHU and running the heating pump. But .. we all know that assumption makes an Ar*e of U and Me.
Any thoughts?
(Apologies.. this is on a 2017 Bailey Autograph II)
Any thoughts?
