Niesmann & Bishoff Arto
Niesmann & Bischoff
Shortly after starting our European trip this summer the 12v power to the fridge stopped working (ok with 240 & gas) also stopped working to the dish and cigarette lighter points.
12volt supply to lights also all ok.
All fuses seem to be ok…?
Start by replacing all the fuses or at least test them to make sure 100% that they are not the cause .
When you say “the 12V power to the fridge stopped “ do you mean that you have verified that there’s no 12V power to the fridge or do you mean that the fridge isn’t working on 12V?
Ian
How are you checking it while driving, which is the only time the 12v works?
Thanks. That's going to be my job today...
It is yes..
Ian
The 12volt light at the switch stopped working (the one that changes between 240volt 12 volt & gas) & the fridge also stopped working..
On our Fiat Ducato based Burstner, there is a 20amp fuse on the + terminal of the cab battery that controlled the 12v supply to the fridge.
So is the fridge working on 240v and gas? if yes it must have 12v to run the controls, at the back of the fridge you should find a couple of heavier 12v cables that run the 12v side so it might be worth checking if there is power there.
