Hi. Does anybody have a new Swift Voyager 594 automatic? If so would you recommend it?
I would be greatful for any reviews.
Thank you.
Thank you.
Let hope it performs like the ZF box as most of the big car manufacturers us zf.Hi
Thanks for a reply, however I have a 2019 Swift 594 with semi automatic gearbox and only 10,000 miles Although it drives well especially after a remap there have been to many things that needed fixing. Replacing airbag module, clutch oil replacement, fixing drain pipes in engine, (common fault, water dropping onto plugs,) changing cam and drive belts, and more. All issues before remap. By the way Fiat are changing from a 9 speed gearbox to an 8 speed japanese gearbox.
Hi.Let hope it performs like the ZF box as most of the big car manufacturers us zf.
Do you know who supplying the new box.
ThanksI don't own one but did look at one as a possible change. My thoughts were that the weights and payload were not practical for a 4 berth van. It was being built on the Ford light chassis with only 370kg payload and there was no towing capability.
Also there were many reports of the injectors on the transit engine were still failing.
