Wow, that's costly.They say every 4-5 years. I had mine done when I bought it at the end of 2019.
Belt went in Belgium a few months ago so just a tad past the 5 year mark.
£4500 to repair never mind the repatriation costs.
I'll always get it done on time from now on.
Both.So is it the time factor or milage, I originally asked last year(5 years) if it needed replacing the guy at the Fiat Professional garage said because of the low milage give it another year
Suggested replacement at 5 years or 100000 miles whichever is sooner
He also said that replacing the water pump is not required
I'd guess that 5 years with less than 8,000 miles covered might indicate it's spent a lot of time without use.Both.
Mileage obviously puts the belt through more wear and tear, but leaving the belt in one position, for weeks or more at a time when the vehicle is not being used, is also bad for it as rubber components can become less flexible if not regulally used.....
Depends on the type of tyre to some extent.I'd guess that 5 years with less than 8,000 miles covered might indicate it's spent a lot of time without use.
I'd be as concerned about the condition of the tyre walls with the weight all on the one spot.
Unless of course its covered many short journeys over that time.
If you don’t do it and it goes wrong, you don’t have a leg to stand on.Do we really need to change the cam belt after 5 years on a Ducato
Here is the old belt I requested back after fitting a new one 6 years almost 8000 miles
No sign of splitting or ware that I can see
I think that’s a good price for a Fiat Professional dealership as I assume they’ll be using the full genuine Fiat kit. I paid £1040 at our FP dealer about six years ago for the genuine kit, service and MOT on our A class.I’ve got exactly the same dilemma. Fiat Ducato based Dethleffs, 5 years old in September, 18,000 miles. Our local Fiat Professional garage said we could wait another year or two as the mileage is relatively low. I’m pleased they didn’t hard sell the need to change the belt but ultimately I’ll be the one picking up the bill if it breaks. They quoted £860 for cam belt replacement and the 2 year service. Does that sound reasonable or should I shop around?
That seems a very good price, which garage ?I’ve got exactly the same dilemma. Fiat Ducato based Dethleffs, 5 years old in September, 18,000 miles. Our local Fiat Professional garage said we could wait another year or two as the mileage is relatively low. I’m pleased they didn’t hard sell the need to change the belt but ultimately I’ll be the one picking up the bill if it breaks. They quoted £860 for cam belt replacement and the 2 year service. Does that sound reasonable or should I shop around?
I was expecting to change the cambelt on my Seat Arona next year at 5 years old. However the dealer said ther gas been a change from VAG & the belt is only replaced on mileage and should only be inspected during service. Mileage they said it needs changing at is 150K.This Skoda drove in for a belt change, yep was still running, but possibly not for much longer and just in time servicing me finks. Costly to not have it done.
Think it’s like playing russian roulette. Driving style, climate, age, mileage all play a part in this and just depends on how lucky you feel.I was expecting to change the cambelt on my Seat Arona next year at 5 years old. However the dealer said ther gas been a change from VAG & the belt is only replaced on mileage and should only be inspected during service. Mileage they said it needs changing at is 150K.
I'd get an independent to change it with the kit (water pump, and also guides, iirc)I was expecting to change the cambelt on my Seat Arona next year at 5 years old. However the dealer said ther gas been a change from VAG & the belt is only replaced on mileage and should only be inspected during service. Mileage they said it needs changing at is 150K.
Where are you based ??I’ve got exactly the same dilemma. Fiat Ducato based Dethleffs, 5 years old in September, 18,000 miles. Our local Fiat Professional garage said we could wait another year or two as the mileage is relatively low. I’m pleased they didn’t hard sell the need to change the belt but ultimately I’ll be the one picking up the bill if it breaks. They quoted £860 for cam belt replacement and the 2 year service. Does that sound reasonable or should I shop around?
Thanks, but I'll follow the manufacturer (VAG) recommendations. Ill not be keeping the car more than another few years so not worried, but if i was id probably change it at 100K miles. I was wrong about the time though its 15 years or 180k miles. Just dug this out from SEAT. I guess it depends on the age of car/ which variant engine you have but mine falls into the directive below.Think it’s like playing russian roulette. Driving style, climate, age, mileage all play a part in this and just depends on how lucky you feel.
My cars 20 years old, but 124,000 miles. It’s soon to have its 5th belt, but following the example of 150k miles, then the car could be 30 years old before it’s changed.
Do you also actually trust anyone who says they’ve inspected your belt during a service. Only way to check a belt is to remove it and that ain’t never going to happen.
I’d still have it changed on your car.
So am I , will send a PMJust outside Newcastle under Lyme
