- Jun 21, 2018
- 506
- 1,689
- Auto Trail Comanche
- Since 2010
Just purchased new leisure batteries, and it says they are sealed maintenance-free but do have vent holes, do I set my Solar controller to vented or sealed?
Whilst waiting for a response on this thread I messaged Tayna who I purchased them from asking if I should remove the transit plugs from both ends of the battery and what to set my controller to ,this is there reply "No you can remove 1 which is adequate for venting - Please set it to vented."On the PCM 2012 you need to make sure that the 'wet' setting is selected which has the 14.3v bulk charge and a 13.2v float charge.
You should select the sealed option on the controller but I would also make sure that the batteries have vent tubes connected too - just in case.
Buy the fitting and tube from B&Q, other wise they are horrendously expensiveNothing to stop u using a tee connector so only 1 pipe to outside air.
