DaveH46
I took delivery of our new Bailey 79-T a fortnight ago and so have now had chance to snag it properly.
Overall the van seems quite well made, but there are quality control problems evident.
So far the list is as follows:-
1) van came fitted with the wrong soft furnishings and trim (headboard panels) Despite ordering 'Grosvener' trim, the van came kitted out with the 'Berkley' trim. To add insult to injury, the build docket in the kitchen drawer was clearly emblazoned with our name and 'Grosvener'.
2) in addition to the wrong trim material, one of the bedroom headboard panels was fitted the wrong way round...two panels with the pattern horizontal, one with it vertical !!!
Another coup for their "Blunkett Charles and Wonder" quality control team.....
3) Water tank .. does not overflow when filled. This leads to the tank eventually getting enough pressure inside to force water out past the hose and level sensor seals in the top of the tank. I have seen several similar threads from owners with this problem. Looking inside the tank with a borescope reveals that there is what appears to be an overflow boss in the offside left corner of the tank so it's either blocked or has not been drilled out/connected up. It's a toss up between fitting a properly engineered vent to the top of the tank myself or trusting the YTS lads at the dealers to pull the tank out, disturb all the insulation etc. and look for a solution.
4) Horrendous whistling noise from the overcab skylight over 50mph ...have carefully realigned seals and catches and will see if it still does it when I take it out later today....
5) USB charger over hab door not working - a quick removal of the control panel gives access to the wiring at the rear... it had been fitted with the +ive and -ive connections the wrong way round ! - now sorted !
6) Solar controller not working properly - the connection to the hab battery has two red wires instead of just one as fitted to the other terminals. These had been crudely stripped and twisted together to make a 'single' wire, the diameter of which is much too thick to be properly inserted into the screw terminal. Despite the terminal being fully tightened, the wires were just 'resting' in the unit and not screwed into the terminal. Wires properly mated together to a reasonable diameter and all is now working as it should.
Nothing too horrendous at he moment, but why these simple things escape notice is beyond me in this day and age....
The dealer has the correct trim panels on order by the way... simple job to swap over..
