- Nov 2, 2022
- 104
- 104
- Mooveo C6 2010
- I'm New!
Does anyone recognise the switch below? It appears to go nothing at all, but does anyone recognise it as a switch off anything specific or just a generic switch?
In that case they probably fitted the switch to fill the hole in the 'wrong' fascia panel.That was my first thought, but it’s a gas only combi 4. Doesn’t effect the heating performance at all.
I’ll pop it out tomorrow and see if it’s wired to anything. I’ve got an awning light to install. At least it would save me a switch!In that case they probably fitted the switch to fill the hole in the 'wrong' fascia panel.
Not checked that yet, could be an option. It doesn’t light up though.Could be the waste tank heater
This crossed my mind, there’s no crash protect on the regulator, but it might be from an previously installed oneLooks like the gas crash isolater solenoid switch. It needs to be turned on to allow gas to flow from the regulator. If the solenoid is still fitted then you can travel with the gas heating on but sometimes they are removed when regulators are changed.
