my Thetford toilet flush has stopped working, looked under the panel and there is printed circuit board which also supplies the lamp for a full drain tank. any ideas?
The pump can seize after a prolonged period of lack of use, remove the circuit board and you should be able to get the pump, try and rotate the impeller by a screwdriver up the inside and fingers crossed it frees it
