My set up ( may be of interest to someone )
Jaws
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Having now had a chance to test the system semi seriously ( 5 days off grid , no engine starting ) I am happy ( for now :-) ) and can pass on the info to anyone interested.............
I have one 3kw ( 230 aH ) unit I got from from https://www.lithiumbatteryshop.uk/ over in Ipswich
The chap builds them in house.. Mine was £780 but I know they have gone up to £840
Why I chose him
He is local and invited me to go take a look at the build process
He was MUCH better priced than any where else
Each unit is custom built with grade A cells
When I did not understand a set up parameter he was a fone call away and helped me out
He has since built two other packs for me ( odd ball ones for odd ball apps ) and repaired a pack that came out of a golf cart thing by replacing a few crapped out cells and resetting the BMS
They come with a decent BMS that has blue tooth and an easy to use app
To support the system there are 4 x 125w solar panels ( If I was doing it today I would just use 2 x 250w panels ) utilising a Victron 100-40 MPPT controller ( also blue tooth )
I disabled the on board mains charger and bought a stand alone 20A lithium specific unit from fleabay for £35
I also added a Sterling 60A B2B unit which really does a good job at shoveling the amps back in between park ups if the weather is not solar panel friendly :-)
Whist away in a field last week we used blown air heating at night, the telly for at least 7 hours ( poor Mo was stuck in the van a lot ) plus all the usual stuff like lighting, fone and tablet charging, water pumps etc etc
By the time I got up around 8am the batteries were back to full every day
With a 230aH battery it is the almost the equivalent of having 4 x 110aH lead acid batteries in safe usable power for a third of the weight
Lead acid is safe to 50% discharge so 4 x 110 gives a total of 220aH usable before a risk of cell damage
230aH lithium which can safely go down to 10% ( actually lower if needs be but I lean towards caution ) gives me about 210aH of power
On top of that lithium is good for at least ten years, I was replacing my £440 worth of lead acids every 3 years, so even fiscally the lithium makes a lot of sense
Your set up sounds great and I am sure you can now use your captured power for a lot more than you describe, even getting a compressor fridge should you need to.
I just wanted to put my experience to reassure others who may feel that lithium is the only way to go.
We still have the one lead acid that was installed at new build in 2015 and we have a 100w solar panel.
We were also off grid at Swaffham of course also using heating before bed and first thing in the morning. Maybe not as much TV. We were there 4 nights.
However, at Easter Rally at Quackers, there was hardly any sun, we were there 6 nights and had the blown air heating on all day. Charging phones and ipads and TV of course..
Nicely done !
I think over all we must be very heavy users ( 32" tv does not help LOL ! ), as we have killed a 3 x 110aH setr up in a few days in the winter
Perehapsd I am overly cautious as once lead acid drtops below 12.2 v I consider that is safely their lot
Nicely done !
I thgink overr all we must be very heavy users ( 32" tv does not help LOL ! ), as we have killed a 3 x 110aH setr up in a few days in the winter
Maybe I just don’t look ! 🤣
…….. and I am scared now that I have jinxed it
