CamperJack
I have used a 6mm2 solar extension cable with a 70A rating to attach my 2 x 170w panels to my controller.
The cable run is 7.5M. The amps are 9.93A per panel so in parallel that's about 20A. The Voltage per panel is 22.8V, in parallel the total remains 22.8V.
Putting this into the calculator below says a wire of 6awg should be used. 6awg is equivalent to 16mm2, which seems HUGE and examples online have a rating of 110A. However the calculator also says that 6awg should have an amp rating of 75A, which is closer to the 70A rating of cable I used.
So is my 6mm2 70A cable correct, or not? I'm getting to the point where my head is totally battered, and the more I look into it the more conflicting info I find, so advice would be much appreciated.
Thanks in advance.
solar powered calculators, solar panel calculator | Renogy
Renogy's Solar Power Calculator Tool can quickly help to estimate your solar power requirements, calculate the size and cost of an off-grid solar system needed.
www.renogy.com
Thanks in advance.
