my globespan summit 640 pump not working
Dodgydave1
globecar
Can anyone help plenty of water. Fuses ok pump not making a noise any help please
Is it your first try this year?
Do you have a test meter? (Every motorhomer ought to; a ten quid one will suffice for basic checks).
If so, check for voltage at the pump - when turned 'ON' obviously.
Fuses can 'look' O.K. but be blown. Best way is to check them with a meter.
There was a thread yesterday that may give you some clues/guidance..............
Chances are you have left the tap slightly lifted but not enough to let water out, the switch in the tap makes the pump run , no water can get out and the pump fails due to running but not pumping
new pumps are cheap and easy to get , buy two and carry a spare
Our Summit Prime pump stopped working last year, despite giving it a good shake. Took it in to be changed, under warranty, they changed it, but said that actually it had stuck. Not sure what had stuck. We are not good at this sort of thing. So maybe take it out and see what you can do. This was at the height of parts shortages, they ended up putting a more powerful pump in, which is actually much better, flushes the loo properly now.
