Muppetry in action today
Newcastle under Lyme
Hymer B544 A Class
Since 2015
My temperature controller for the fridge fans expired recently so I had a fiddle with it today to remove and replace it.
But . . . . . now I've no 12 volts to the fridge at all :doh:
I've replaced the 20 amp fuse on the EBL to no effect.
It's a dometic 6401 and EBL 99 on 2003 Hymer / Fiat x244
Any suggestions please ?
Fridge electronics are normally supplied by a 2 amp fuse separate to the EBL.
Is that the fuse next to the cab battery ?
Normally next to the cab battery there is a 50 amp fuse that is the main feed to the EBL and a 20 amp one that is the supply to the fridge relay inside the EBL.
My van has a Fuse block beside the EBL that has the 2 amp fuse in it & fuses for heater & satellite, may be different on earlier vans.
Mine has the 20 amp fuse on the EBL and a 2 amp next to the 50 amp by the cab battery.
I've replaced both but still no 12 v to fridge.
The only thing I've touched on the fridge are the + and - wires that come out the top vent and connect to the fans 🤷‍♂️
I'm wondering if there's a fuse on the actual fridge but manual doesn't suggest there is one
There must be another one somewhere so I'll have a look for a separate fuse block by the EBL
