Movable shower wall retaining clip
UK
Burstner
Few years now
The retaining clip for our movable shower wall in our Burstner seems to be getting a bit weak and I want to source a replacement before it fails completely.
has anyone found anything a bit mor substantial or do I need to replace like for like?
Howard
There is a guy on here who does 3D printing who could probably help you out. @PaulnChrissy or something like that. His products are very good. He might see this post
Howard
Hi there
We are back home on the 12th. Send me a PM and I will see what I can make for you.
Cheers PaulandChrissy
Hi Paul
Thanks for the offer. The clip in the photo still works, but the peice that drops to hold the partition isnt as strong as it was so it moves slightly when driving.
I was really after a metal retainer which may be a by stronger.
Howard
Hi Howard
Can only make things in plastic on my 3D printer. Sounds like you need to get crafting on a bit of ally to get the strength you’re after. I can make it more robust in plastic by redesigning it. Would need your original one to work from if you decide to go down the 3D printed route. Back on the 12th if I can be of any help.
thanks. Will probably look at something with a bit of aluminium .
Thanks again
If it helps, Hymer use the same sort of clip, so it may be possible to get a replacement from the likes of Brownhills if it's used by several builders.
Howard
This is the clip that is used on my Hymer shower.
Howard
Did you ever find a spare clip? I'm looking for the same reason.
If you can’t find one, or the new ones are flimsy, you could send me your old one, I could try to design and 3D print a new one. Have you got a picture of your clip.
