Motorhome wiring diagrams - are they available
Benimar 202
Hi I have had a motorhome Benimar Mileo 202 for 7 years - all good.
Today no power certain parts of system - no dropped out breakers or main fuses blown - so struggling without tearing up floorboards.
No 12v to fridge or heating controller.
Are wiring diagrams available?
Tombola
Merseyside
Rapido 8094DF
Since 2004
Not sure about wiring diagrams..what system is it, sergant, cbe ?
Can you explain in more detail.
Has the main battery fuse been checked usually 50 amp within 30cm of the battery lead..
Or other fuses
Hiffy166
Benimar 202
Thanks for comment Mr T,
The main 12v system seems OK - the panel above the door lights up and the water pump works - the lights work - the leisure battery level is at max.
If I plug in 240v mains in it makes no difference. Its just the heater control and fridge that have no 12 volts.
I will revisit tomorrow - maybe something simple - it usually is!!
Bracklesham Bay, West Sussex
PVC
I think your 12v PSU may be a CBE DS300 unit/fuse box and , if it is , it could be worth checking the 3 amp fuse(second in from the right ) as it appears to be linked to both the fridge and heating operation
Hiffy166
Benimar 202
Geoff - Many thanks - yes found the drawing in the PC180-OC manual - the DS300-EM drawing fuse 9 - will check tomorrow.
I checked the high value fuses (intuitively without the diagram) !!
Thanks again.
