I just have standard EHU and an adapter with about a foot of cable to a normal 3 pin plug - use that at home and unplug adapter if EHU point. Cost me about a tenner -amazonThinking of fitting a more permanent exterior power supply to have the motorhome connected to when at home - have found this option https://www.toolstation.com/industrial-socket-ip44/p85589 - what other options like this does anyone have?
Keep in mind your next car will be electric.
Therefore don't waste money installing something that will be useless in a few years.
Get proper cooker cable installed direct from your consumer unit with a proper car charging socket as well as a standard EHU socket
Make sure it's all more than shower proof.
Also make sure it has a cooker/immersion type switch with a red LED inside the house to isolate the sockets.
You don't want some scrote charging up their car using your power every time you go off to work.
(Theft of electricity is a virtually unheard of crime today. A decade from now however it will be one of the regular offences coming up in the local courts.)
…and your point is?The one in your photo is IP44 rated the same as your Motorhome connectors, the one in your link is IP67 rated but will only retain its IP67 rating in use if you connect to it with an IP67 rated plug - I bet you don't.
Yes, one house we looked at had, what was even to me, squirrelly wiring. I got an electrical survey done which told me the worst. Along with the other issues surveyed, I pulled out of the sale and gave the reasons why - as the electrics had been condemned, I sent them a copy of the report. The subsequent purchasers of the house never knew about it……..Yes
Yes I agree, but you are highlighting my point. In many cases they are not correctly wired. Mine isn't. It was already done when we bought the house. Its a spur off the last socket (furthest away) in the Kitchen. The MCB will offer little protection as it is rated for the whole circuit. This spur is not suitable for anything like 7kw. The only answer for me would be to install a proper DB (like at a campsite) for my plug in.
No danger as such just that you can't make use of the IP67 rating without the correct plug so might as well fit an IP44 socket.…and your point is?
Nothing different to when I plug in on a campsite using my supplied EHU lead. I wanted an properly installed IP rated external connector with installation certificate (both for that and for the garage wiring) that would pass an electrical survey and that is what I got.
Please can you enlighten me on the consequences apparently dangerous practice of connecting a normal IP44 rated plug into the IP67 rated socket, which it seems that everybody else does?
Unless you are simply trying to score points……….
I still do not see the point of you raising this as an issue. I needed a socket that was approved and would stand up to things like jet washing the driveway, heavy rain etc...... which is what I got.No danger as such just that you can't make use of the IP67 rating without the correct plug so might as well fit an IP44 socket.
