motorhome cabinet veneer peeling
pwilmo
Kings Lynn, Norfolk
Auto Roller 747
My Bessacar is a 2006, and in several places at ends and edging, the veneer is curling or peeling off.
I have researched it to some degree, where it is advised to gently warm the veneer and stick it down, but the type of glue is not mentioned, I'd have thought superglue was not suitable.
Any funsters had similar repair experience and maybe able to give recommendations for a suitable glue/adhesive?
Contact adhesive will do the job nicely, I had the same on my Bessy
I used Evostick contact adhesive. Follow the instructions and apply some masking tape to make sure it stays put.
I have found some edging is really well stuck down but a small part will lift with your fingers. This could become a big problem if not dealt with. I dispense a small amount of superglue onto a piece of waste card. I then use a small piece of card to collect some superglue on the tip. Lift the offending edge gently and use the card with the glue on to glue. Keeps it from getting worse and stops you catching it accidentally
Thank you people, I'm off to buy a gallon of evostick, it's great to have advice from Funsters who have been successful in motorhome veneer repairs.
Greatfully Received, now hunting down all the peely bits.
