Motor home not starting
Clint
Benimar
Battteries are fine but motorhome making this noise when trying to startšŸ˜¢any ideas
  • FullSizeRender.MOV
    5.8 MB
If you are sure that the starter battery is fully charged , It could be a poor/loose starter battery terminal or earth connection not allowing enough power through to enable the starter to operate fully.
Thanks, I ran it this afternoon for 1 hour, turned it off then this, some one suggested alternator beltšŸ˜³
Does the Motorhome control panel show what the battery voltages are ?
No , but weā€™ve had the leisure and main battery checked and both up to capacity
You could try a jump lead from battery negative lead to engine block. This will show if you have a failed engine earth strap reducing the power available to the starter.
Make sure coil light is off before trying my car did it in the very cold. Had to warm the coil 3 times then she fired up.no.problem .Good luck
