MOT help
Tombola
Merseyside
Rapido 8094DF
Since 2004
when I go to check my MOT history of the Rapido I bought back end of last year I get this
but when I go to add it to get text reminders I get vehicle not found https://prnt.sc/uQw6X5niLxkI
anyone know why ?
i have checked the reg and all is ok
Is it within mot years ie 3 or more years old?
no, thats what led me to search tbh, I couldnt find any info. Looks like my last outing was possibly MOT less.
when I go to check the current MOT status i get this
but then again this
If you can’t find it on the database then no one else can 🤔😊
Worth contacting DVLA maybe.
It’s obviously on at least one database as you’ve got it insured.
You could check that one as well.
Also you could do a cheap HPI search for around a tenner.
No point contacting the Police they don’t help in civil enquiries I’ve found.
V5 correct? Change of number plate perhaps?
Mine is the same, we have had it from new and three years old,in October. Doesn’t show a MOT required date
No change in registration number, however has been upplated from 3500 to 3850kg.
I was trying to work out what MOT required due to its weight.
Regardless of what the history shows it should have had an MOT on 1st march this year.
Just get it tested then see what the record says.
Did you put a space before the last three letter? If so remove it.
My car last three letters are OOG & some insurers etc cannot recognise it. I think they may be putting 00G (ie 2 numbers & 1 alphabet instead of 3 alphabet)
Might sound silly but just a mere female none driver, would a zero 0 or letter o be in your reg and if mixed up cause the problem 🤨
Amongst other rules and info.
For example the letters ‘I’, ‘O’, ‘I’ and ‘Z’ are never seen on number plates because they look too similar to other letters or numbers.
The letter Q is not used currently either, but it was used as a prefix up to 2001 on stolen and recovered cars that couldn’t be reliably identified (e.g. ‘cut and shuts’) and kit cars made from elements of various different vehicles.
