Some more Adria mysteries for you geniusses (genii?) to solve !
Attached photos:
one shows side of greyW tank. when I turned the tap, nothing came out. Either tap has been open since I bought the van and continuously emptied itself, or there's a problem with the valve. Tap handle will only turn 90% - Which positions are closed / open pls ?
(Burstner was simpler - just a tap on the outlet pipe)
And I just noticed this pic has a white pipe nozzle in the left background with no pipe attached to it - whats nozzle for ??
Other 3 pix are a little device adjacent to the water tank. It appears to have an adjusting knob, but also 2 electrickery wires going to / from it. Anyone enlighten me it's function ?
Also: I was blowing down the shower hose to empty tubes as previously advised on here. Had a realisation that because of different tubes, shower tap needs turned to HOT and other HOT taps opened in turn to allow expellation. Then shower tap needs turned to COLD and repeated with other taps COLD in turn.
That seems to work ok now I got my head around it. Didnt seem to blow-thro properly in the Burstner - but maybe I didnt open taps in sensible order back then. (Pointless exercise if shower is set to HOT and COLD tap opened in sink - different pipes, no thro connection!)
_
_
Attached photos:
_
_
