Mixing different brands of lithium batteries (2 Viewers)
Lizbiebrowne
413
509
Teesside
Hymer B654
Since 2019.
I have a KS Energy 120 Ah lithium battery and want to increase my capacity by adding another battery. I notice that the Foster batteries are significantly cheaper than the KE Energy batteries. Is it ok to connect up, in parallel, batteries from different supplier and also different capacities?
MichaelT
3,855
7,984
Colchester
Carthago I 143 LE
Since 2016
I've got a 200a KS and a 280a Fogstar, all work fine and discharge and charge roughly equally so far. Join via a bus bar then take feeds and charges from them so solar controller and shunt just see one big battery and have the cables exact same length to the bus bars.
Steve and Denise
5,568
15,229
Spalding LINCS
A Class Carthago
Since 2008
I have a 300ah Roamer been fitted 2 years now and was looking at doubling up so contacted Roamer and they advised against doing this due to cycles used and balancing.
They did however say that it could be done with more attention to balancing needed.
But I am no expert
MichaelT
3,855
7,984
Colchester
Carthago I 143 LE
Since 2016
But I am no expert
I think that's roamer using different cells
Jan 30, 2020
3,528
16,742
Mid Bedfordshire
RS Endeavour
Just a tad..
But I am no expert
They obviously want to sell you two battery’s Steve! 🤪
Steve and Denise
5,568
15,229
Spalding LINCS
A Class Carthago
Since 2008
Unfortunately they don’t now do a 300ah it’s been replaced with a 320ah and a later bms I think I’ll just stick with the 300 at the moment as I have upped the solar to 700w ready for the compressor fridge for the winter period, so time will tell
Jan 30, 2020
3,528
16,742
Mid Bedfordshire
RS Endeavour
Just a tad..
Doesn’t matter how much battery you have, as long as you're consuming and storing the solar you’re generating it’s fine… so makes sense to stick for now! 👍🏻
I’m now up to 920w of solar, although 320w is folding rigid mono panels so I can harvest low winter sun… the balance 600w roof mounted is fine the rest of the year! ✔️
MichaelT
3,855
7,984
Colchester
Carthago I 143 LE
Since 2016
I think they are prismatic, so are you saying all other manufacturers use the same type of cells as each other? as I thought there were quite a few different ones.
I dont know what the difference is but KS, Fogstar et al use EVE cells and Roamer Prismatic.
