Microswitch
slider
ducato
Hi everyone, i bought a fiat ducato adria coral 600 SL and its missing a shower, the 2 hot and warm water pipes are there but i dont see a microswitch wirelead, i wonder is this needed or not?
Me too.
There should be a hot and a cold pipe. The microswitch will be in the tap head to turn the pump on/off.
What's missing in the shower ?
ah great ! thanks, sorry for the confusion - i only have a warm and cold water hose leading up to a hole where the shower used to be...my previous campers always had a microswitch hence i was confused!
you should have a sureflo pump and a small basic accumulator ( a plastic bottle that partially fill with water ) somewhere in the cold line near the fresh water tank.
if you check under the sink you will see there are no wires to any tap.
yep seen it ! are you an expert on Coral campers Phill D i got some more questions ;)
i'm no expert but i have had our coral for 12 years and have tinkered with most of it.. ;)
PS ; ask away if i can help i will and i am sure there are many others who will know what i do not.
a word of warning if you have not subscribed as a member you only get 5 posts.
