I disagree with having traps in van UNLESS you know you have a problem... and if you do, believe me, you will know..I have six traps distributed around my van. Caught the first one today. I caught six last winter. I find Marathon/Snickers to be the best bait.
I only started with the traps after finding a dead mouse in one of the drawers in the van a couple of years ago, it had been feasting on the water pipe insulation.I disagree with having traps in van UNLESS you know you have a problem... and if you do, believe me, you will know..
IMO baited traps are a food source to mice and will attract them into van when normally they would not bother
Yes totally understand.. however my point was, could the mice you are now catching be attracted to the bait on the trap..I only started with the traps after finding a dead mouse in one of the drawers in the van a couple of years ago, it had been feasting on the water pipe insulation.
I have 2 cupboards in my garage one has had visitors the other nothingAny ideas about stopping mice getting in I've tried stays and sonic sounds they aren't working
I disagree. The gas dropouts should already have mesh coverings. If plastic, add the alloy stuff used to repair bodywork. All entries through the bulkhead should have grommets or the like. As said, our first van they got in by the pedals where the gaiter was not properly fixed.I don't think it's possible to prevent them getting in unless you block every tiny hole including those on the bulkhead and all the gas dropouts.
Place traps around your wheels as this is how they get in.
I put a box over the traps with a mouse hole in to the trap.
This method stops you killing the robins and wrens that will be normally hopping around your van eating the spiders.
I use a thin aluminium that I crafted into a box shape, but anything that allows the trap to spring without hindering the action will work.
Also put a weight on top of the box as you don't want the wind to move it and set the trap off.
Next check every morning and clear/ rebait.
Find peanut butter works quite well and does stick to the trap.
Next after a bloody kill clean it off with a brush and soapy water.
Good luck.
