Bernie Jones
- Mar 11, 2018
- 2
- 0
Hi all,
I've recently acquired a 2008 model of the above and wish to replace the current towbar with a carrier for a lightweight motorcycle. I've done all the calculations to work out what the resultant weights would be on the front and rear axles and am planning to get the vehicle uplifted to 3850kg with a 2240kg capacity on the rear axle with the help or air suspension and uprated tyres. That will ensure that I'm legal w.r.t the axle loads.
However, trying to determine the permitted safe load on the towing carrier - i.e. combined weight of bike plus carrier - is proving elusive. The Autotrail documentation doesn't mention it at all. The Fiat handbook gives figures for a number of variants of the basic vehicle but not of course for the conversion. I'm not even sure which chassis model the conversion is based on (the Fiat handbook refers to a standard and heavy version of the 3500kg model with max nose weights of 100kg and 120kg but I don't know which I have). Also, these figures refer to the SWB and MWB versions so I suspect might be reduced for the Autotrail with around 1400mm overhang from the rear axle to the towing hitch.
Any advice on how I can derive some figures to determine the maximum load would be hugely appreciated!
Many thanks,
Bernie
Many thanks,
Bernie
