Mango toll tag placement
Bristol
Burstner Ixeo 680tl
Since 2017
Grateful for advice re placing my Mango (Now Fulli) tag. The website says place to the left of the rear view mirror but the French note supplied with the tag says to the right (droite). Secondly so I place it in the clear area of the windscreen or the darkened area around the mirror mount?
I've just go the Emovis tag and wondering where to put it. It says on the shaded bit by the rear view mirror. We we don't have a rear view mirror. In it's place is the gubbings for the rear view camera and I don't want to stick it where it will foul the Remis blinds. First world problems :giggler:
Sue
You can just keep it on the dashboard and wave it in the air (it’s what we did when we “borrowed “ it for the car). It will work anywhere except under a big overcab overhang.
Sue
We just have ours in the little tray/pocket on the dash top. Didn’t always work stuck to the window top. Been good for 5 years now.
It there is space then still k it in the darkened area behind the rear view mirror location. This is the area specifically designed for such devices. I think it's called the heat resistant area where electronic signals can pass easily. Our Fulli tag is there and I can still close the remis blind ok.
Kups - if I stuck it there the beam would need to go through the black box that holds the rear view camera gubbings. I can only just get the blinds over the box as it is.
Sue
Sue
Not sure what you mean. The tag is mounted on a sticky pad bracket that goes onto the inside of the windscreen. The toll gate signal and response from your tag only goes through the windscreen glass if mounted this way.
Our is mounted in the darkened area just to the right of where the rear view mirror would be if we had one. Works perfectly.👍
Kups - I think my problem is I'm assuming the tag needs to be in the top centre of the windscreen. This is impossible for us as indicated above. The beam could not go through the black box which holds the rear view camera stuff and would prevent the blinds closing. I'm going to adopt Riverbankannie's method ::bigsmile:
Sue
Blinds mean we can't stick it to the screen. Tried it on it dash and it didn't work. Getting the passenger to hold it out towards the windscreen on the approach to barriers seems to work.
